Dazzla_20011's avatar
Dazzla_20011
Aug 15, 2011
Block users from connecting to a virtual server using ip address
What’s the easiest method to block users from connecting to a virtual server using an ip address. We only want to allow connections which match the url.
Darren
  • Hi Darren,
    You can create a simple irule such as the following example:
    The following example blocks any users not entering the correct URL
    set host [string tolower [HTTP::host]]
    set uri [ string tolower [HTTP::uri]]
    if { !(($host eq "www.yourdomain.com") and ($uri starts_with "/url" )) } {
    reject
    Another example is blocking based on an specific clients IP address
    when CLIENT_ACCEPTED {
    if { [IP::addr [IP::client_addr] equals 10.10.10.10] } {
    reject
    or blocking all addresses except a single address
    if {! ([IP::addr [IP::client_addr] equals 10.10.10.10]) } {
    reject
    You can get more sophisticated by using the class function when you need to block multiple client ip addresses in different ranges
    http://devcentral.f5.com/wiki/iRules.class.ashx
    I hope this helps
    Bhattman
  • You can go more generically with a scan command:
      if { [scan [HTTP::host] {%d.%d.%d.%d} 0 0 0 0] == 4 } {
        HTTP::respond 200 content "Please use the hostname!"
