MustphaBassim's avatar
Sep 09, 2022
block traffic from outside to inside
Hello Dears
I had setup Vriutal server the Servers in vriutal server can access to anything in network ( from inside to outside ) while from outside to inside it's not enable to reach them on their private IP
could anyone help me plz.
Bests
  • Hi MustphaBassim,
    So i think you can create virtual server type forwarding IP and allow just vlan Internal for go to outside, This's setup all traffic from external cannot access to internal
    I hope this information will help you
     https://cloud-ttrust.com/
    • MustphaBassim's avatar
      MustphaBassim
      Icon for Cirrus rankCirrus
      hello dear and thnx for reply
      the Vritual server setting is standered one and for protocol i had put Protocol is all traffic permited
      • T-Trust's avatar
        T-Trust
        Hi
        So i think, You can select internal vlan on option VLAN and Tunnel Traffic within virtual server for allow just vlan internal go to outside and all traffic cannot hit this virtual server
