rafaelbn_176840's avatar
rafaelbn_176840
Jun 09, 2018
Block specific SOAP method without ASM
Hello Devs!
Is it possible to block a specific SOAP method without ASM? Could an iRule do this?
Thanks!
  • Hi,
    You can use an Irule:
      if {[string tolower [HTTP::method]] contains "YOUR METHOD"}{
        log local0. "Forbidden HTTP method ([HTTP::method]) attempted by [IP::client_addr]"
        reject
    For example, to reject requests containing the TRACE method, enter the following text:
      if {[string tolower [HTTP::method]] contains "trace"}{
        reject
    In your case you can autorize only wanted method !!!
    For more information:
    https://support.f5.com/csp/article/K85840901
    regards
