Joe_Pipitone's avatar
Joe_Pipitone
Jan 28, 2013
Block appended portions of URI
We have a site in particular where we'd like to only allow a certain few strings to display our webpages, and anything after those strings gets blocked.
For example:
http://ourwebsite.com/directoryinformation/something?something -> gets blocked
http://ourwebsite.com/directoryinformation/ -> Allowed
http://ourwebsite.com/anothersection/ -> Allowed
As far as where to start - would I need to get into string matching, or some type of character matching? I know how to match the string and redirect if needed, however I don't know how I would block further requests if more data is appended to the end of the uri.
For instance - it is my understanding that matchclass is no longer being used in v10 - we are running v10.2.3. So I could create a data group and check to see if these strings match?
Essentially, we would need to accept a URL with the following directories, and pass them through unchanged:
class
match [
HTTP::uri
ends_with
class
match [
HTTP::uri
ends_with
anothersection
class
match [
HTTP::uri
ends_with
forums
I appreciate any guidance.
  • Hi Joe,
    THere are several ways you can approach this. The following is a simple example of the structure of using an irule to block specific paths in the URI
    class blocked_uri {
    "something"
    "somethingelse"
    if { { [class match [string tolower [HTTP::path]] ends_with blocked_uri ] } {
    reject
    [HTTP::path] can be replaced with other commands
    I hope this helps
    =Bhattman=
  • Thank you! I was close, I was using HTTP::uri, but I see now why you used path.
    Would this solution allow for us to allow "something" to pass through, but block "something?whatever.aspx" - meaning, if someone doesn't specifically type "something" then they are rejected?
    Ideally someone going to http://oursite.com/something would be allowed, however http://oursite.com/something?somethingelse would be rejected - this class match would consider this a rejected URI, right?
    I'll do some testing on my end and see what I can come up with. Thank you again.
