matt_wheeler_11's avatar
matt_wheeler_11
Historic F5 Account
Jul 18, 2007
Binary Scan help with an iRule
I am working with a customer where we are trying to grab specific content from a SQL response to create persistence. However, when the rule get to the line where I log line "0004 clientdata: $clientdata" I get the following response in my log file. I was wondering if someone could assist in figuring out where I went wrong. Here is the return in my log file:
Jul 18 13:22:48 tmm tmm[1121]: Rule RecDB-iRule2 : 0002 New client connection from 172.20.5.30:4833
Jul 18 13:22:48 tmm tmm[1121]: Rule RecDB-iRule2 : 0003 Collecting
Jul 18 13:22:48 tmm tmm[1121]: 01220001:3: TCL error: Rule RecDB-iRule2 - can't read "clientdata": no such variable while executing "log local0. "0004 clientdata: $clientdata""
when RULE_INIT {
log local0. "0001 iRule RealEC-iRule initialized"
Convert Text to HEX before Client_Accepted so we only do this task once.
set InsertService "0049006e00730065007200740053006500720076006900630065"
set TranOrigID "005400720061006e004f00720069006700490044"
set TranRefNum "005400720061006e005200650066004e0075006d"
when CLIENT_ACCEPTED {
log local0. "0002 New client connection from [IP::client_addr]:[TCP::client_port]"
TCP::collect
log local0. "0003 Collecting"
when CLIENT_DATA {
binary scan [TCP::payload] H128 clientdata
Look for InsertService 128 bites into the TCP Payload
set svc_event [findstr $clientdata $InsertService 52 ]
If we see Insert Service set Persist
if { [string first $InsertService $clientdata] != -1 } {
Look for TranOrigID, offset 40 (Hex) and stop at &
set trans_id [findstr $clientdata $TranOrigID 40 "26"]
Look for TranRefNum, offset 40 (Hex) and stop at &
set ref_id [findstr $clientdata $TranRefNum 40 "26"]
Concantenate the two values and persist
set db_id $trans_id:$ref_id
if { $db_id != "" } {
log local0. "0005 DB-ID=$db_id"
persist uie $db_id
log local0. "Persisting $db_id to [persist lookup uie $db_id]"
TCP::release
  • matt_wheeler_11's avatar
    matt_wheeler_11
    Historic F5 Account
    Okay that worked but now I am getting the following...man it is a drag when you are new to iRules. Any ideas would be great...
    Jul 19 08:06:51 tmm tmm[1121]: Rule : 0001 iRule RealEC-iRule initialized
    Jul 19 08:07:17 tmm tmm[1121]: Rule RecDB-iRule2 : 0002 New client connection from 172.20.5.30:3413
    Jul 19 08:07:17 tmm tmm[1121]: Rule RecDB-iRule2 : 0003 Collecting
    Jul 19 08:07:17 tmm tmm[1121]: Rule RecDB-iRule2 : 0004 clientdata: 1201003400000000000015000601001b000102001c000c0300280004ff080001550000004d5353514c53657276657200140b0000
    Jul 19 08:07:17 tmm tmm[1121]: 01220001:3: TCL error: Rule RecDB-iRule2 - can't read "InsertService": no such variable while executing "findstr $clientdata $InsertService 52 "
  • Most of the time I've seen variables in the RULE_INIT section defined with a leading double colon.
    when RULE_INIT {
      set ::InsertService "0049006e00730065007200740053006500720076006900630065"
    set svc_event [findstr $clientdata $::InsertService 52 ]
    if { [string first $::InsertService $clientdata] != -1 } {
    I know it has something to do with being a global variable; the programmers on the board could explain the details better than me.
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    Yes, citizen_elah is correct, those should have been defined as global vars, my bad, sorry guys:
    when RULE_INIT {
      set ::TranOrigID "005400720061006e004f00720069006700490044"
      set ::TranRefNum "005400720061006e005200650066004e0075006d"
      TCP::collect
    when CLIENT_DATA {
         Look for TranOrigID, offset 40 (Hex) and stop at "&" (0x26)
        set trans_id [findstr $clientdata $::TranOrigID 40 "26"]
         Look for TranRefNum, offset 40 (Hex) and stop at "&" (0x26)
        set ref_id [findstr $clientdata $::TranRefNum 40 "26"]
          persist uie $db_id
          TCP::release
    Global variables are shared across all connections, so anything that's constant for all connections should be defined as a global variable to save memory. Any variable whose value is expected to vary per connection must be defined as a non-global variable.
    HTH
    /deb
    matt_wheeler_11
    Historic F5 Account
    Here is the irule that I got to work...However, does anyone know how to convert the ASCII into text so that I can just grab the InsertService from the packets?
    when RULE_INIT {
    TCP::collect
    when CLIENT_DATA {
    binary scan [TCP::payload] H* clientdata
    set ::InsertServiceEvent "1201003400000000000015000601001b000102001c000c0300280004ff080001550000004d5353514c53657276657200140b0000"
    set svc_event [findstr $clientdata $::InsertServiceEvent]
    log local0. "0004a svc_event: $svc_event"
    if { [findstr $clientdata $::InsertServiceEvent] != "" } {
    persist uie $db_id
    TCP::release
    when LB_SELECTED {
    After logic is run and server is selected, log which one
    log local0. "Selected server [LB::server]"
  • You can use binary format to convert from HEX encoded ASCII to text. Binary format is just the opposite of binary scan.
