uni's avatar
uni
Nov 14, 2012
bigtop and partitions and folders
bigtop is a much used tool which seems to be neglected these days.
In v11+, can bigtop show objects in partitions and folders other than /Common?
  • hoolio's avatar
    hoolio
    Hi Stephen,
    Yes, at least in 11.2.0+:
                                |  bits  since       |  bits  in prior    |  current
                                |  Nov 13 14:06:35   |  4 seconds         |  time
    BIG-IP      ACTIVE          |---In----Out---Conn-|---In----Out---Conn-|  11:46:34
    ve11a.x.y                    144.8M 272.0M  22371  43808  25120      1
    VIRTUAL ip:port             |---In----Out---Conn-|---In----Out---Conn-|-Nodes Up--
    /Common/10.1.0.120:http       55848  52824     16      0      0      0      1
    /Common/10.1.0.123:http           0      0      0      0      0      0      0
    /Common/10.1.0.122:http           0      0      0      0      0      0      0
    /Common/10.1.0.121:https          0      0      0      0      0      0      2
    /Common/10.1.0.120:https          0      0      0      0      0      0      1
    /Common/10.2.0.120:shell          0      0      0      0      0      0      1
    /Common/10.1.0.125:http           0      0      0      0      0      0      0
    /Common/10.1.0.125:https          0      0      0      0      0      0      1
    /partition2/2.2.2.2:http          0      0      0      0      0      0      1
    NODE ip:port                |---In----Out---Conn-|---In----Out---Conn-|--State----
    /Common/ubuntu1:http              0      0      0      0      0      0 UNCHECKED
    /Common/192.168.1.102:any         0      0      0      0      0      0 UNCHECKED
    /Common/down_node:tick-port       0      0      0      0      0      0 DOWN
    /Common/ubuntu1:https             0      0      0      0      0      0 UNCHECKED
    /Common/ubuntu2:http              0      0      0      0      0      0 UNCHECKED
    /Common/ubuntu1:shell             0      0      0      0      0      0 UNCHECKED
    /Common/syslog_vs_node:shell      0      0      0      0      0      0 UNCHECKED
    /Common/ubuntu1:smtp              0      0      0      0      0      0 UNCHECKED
    /Common/ubuntu3:http              0      0      0      0      0      0 UNCHECKED
    /Common/down_node:60100           0      0      0      0      0      0 DOWN
    /Common/down_node:33000           0      0      0      0      0      0 DOWN
    /partition2/2.2.2.3:http          0      0      0      0      0      0 UNCHECKED
    Aaron
