eesun_276598's avatar
9 years ago
Solved
Difference between partition and folder in F5?
Hi Anyone can explain the difference/relation between partition and folder in F5? I read some documents, but i still feel confused about this. Thank you
  • A partition maps to a top level folder. The Common partition maps to /Common. You can have child folders, it's like a file system. However there are no child partions, so if you are in folder /MyFolder/MySubFolder you are in partition /MyFolder.
  • Andy_Fleet_2425's avatar
    Andy_Fleet_2425
    Historic F5 Account
    • eesun_276598's avatar
      eesun_276598
      Icon for Cirrus rankCirrus
      Thank you for your reply. I think you are right. The folder is located at one F5, but the same partition can be located at several F5, am I right?
