MRA261's avatar
MRA261
Dec 10, 2021
bigip_ucs_fetch with passphrase problem
Hi Guys,
To make a backup, I use the ansible module for F5 "bigip_ucs_fetch".
I would like to add a passphrase to my ucs file. For that I use the option "encryption_password" on my playbook.
The problem is that even if I use this option, the file is not encrypted.
Has anyone ever had the same problem or woulf have an idea for a solution? Is it a bug?
Thank you
  • Hello,
    Probably a very delayed response, but I have also noticed this behaviour.
    Running 'f5networks' version 1.10.0, and using 'f5networks.f5_modules.bigip_ucs_fetch' module - creates an uncrypted file even if the "encryption_password" parameter is set.
    Have any one found a solution to this problem yet?
    Thanks.
