Bigip HA sync Problem
Hi!
we have 2 Units of f5 ver 12 in HA . someone,by mistake start to create objects and a vs in the standby unit. when he saw that he is in the standby unit he started to create the some objects at the active unit and then he pressed on sync to group with the checkbox of overwrite. since then the standby unit is unsynced and we get this error:
Sync Summary Status Awaiting Initial Sync Summary One or more devices awaiting initial config sync Details
F5-02.com is awaiting the initial config sync
Recommended action: Synchronize F5-01.com to group sync-group
we have tried to recreate the a Sync-Failover Device Group but problem still exist.
any help will be appreciated
thanks,
Aviv Hassidim
- StephanManthey
Nacreous
Hi Aviv,
the message "awaiting the initial config sync" typically indicates that units never were in synced state. (Maybe due to re-creating the sync-failover device group.) Please check both units for the device settings (failover, config sync, mirroring). Local self IPs need to be used for all these properties and the port lockdown should be set to "allow default". Both units are added to the new sync-failover device group? Device trust is established bi-directional (check device list on both machines). Make sure both units are on same time ("
"). Watch the log file for error messages during config sync:ntpq -p
Thanks, Stephantail -f /var/log/ltm - stephiez_239090
on both F5, go to shell/ssh, access 'tmsh', type:
list cm device
or try to follow this method: https://devcentral.f5.com/questions/config-sync-issue-both-boxes-are-staying-disconnected-
- Aviv
Cirrus
Hi!
I have tried the solution but it didn't worked for me. i get this now:
Sync Summary Status Sync Failed Summary A validation error occurred while syncing to a remote device Details Sync error on TVLF5-02.com: Load failed from TVLF5-01.com 01070734:3: Configuration error: Modify of node attribute is not permitted. Recommended action: Review the error message and determine corrective action on the device
any suggestions?
Thanks, Aviv- StephanManthey
Nacreous
Hi Aviv, I guess, the configuration is somehow inconsistent. As you mentioned, changes were applied to both units. A logical configuration change (nodes, pool members, virtual servers etc.) should be synchronized in "overwrite" sync mode. If changes were applied to VLANs and self IPs it might become more complicated as the object names have to match in your cluster and i.e. for floating self IPs (which will be synced a VLAN and a matching self IP have to exist on the peer device). I am wondering, if you can locally save the configuration on command line: tmsh save sys config tmsh save sys ucs backup_bigip_date.ucs Thanks, Stephan - Aviv
Cirrus
Hi! F5 support helped me. we deleted all vs &pools & nodes from the standby device and then sync worked perfect Thanks a lot, Aviv
