dirome's avatar
dirome
Icon for Cirrus rankCirrus
Oct 18, 2019
BIG-IQ differences between monitoring and application tab
Hi Buddies,
Do you know, What are the differences between monitoring and application talking about statistics?
Regards,
Diego R.
  • Dojs's avatar
    Dojs
    Hi Diego,
    Monitoring you will se all the informations about your VS, Dos Profiles, Security Profiles, in general.
    In Application tab you will create an Application and will create all the services that is necessary to that App run. using VS. So you will have all the informations in just one line, and go drill down to see more information about each service.
