BIG-IP TCPDUMP Question
What does it mean when the tcpdump is only receiving the initial packets and nothing else?
- Prince
Altostratus
Hi Willian, What do you mean when you say initial packets? TCPDUMP output depends on how you are using it. What type of VIP is present on which you are taking tcpdump? Is it L4 or L7 ?
- nitass
Employee
if you are using pva, turn it off (pva-acceleration none) and try again.
sol6546: Recommended methods and limitations for running tcpdump on a BIG-IP system
http://support.f5.com/kb/en-us/solutions/public/6000/500/sol6546.htmlif you are not using pva, you may check if there is asymmetric routing (i.e. server sends response to client directly - bypassing bigip).
