ndaems_145583
Feb 09, 2017BIG-IP Edge VPN Block mode exceptions
Hi All,
I've a question about BIG-IP Edge on Windows configured to Block traffic flow when VPN is disconnected.
Is there a way to exclude some URL / IP from the Blocking mode? We need this setup to reach a 2FA solution and allow the VPN login... Looks like a vicious circle as VPN is blocking the connection and so 2FA is not reachable and cannot connect to the VPN...
Thank you
Regards
Nicolas
- ndaems_145583
Support confirmed that it's not possible for the moment
An RFE has been introduced
