Doubstar_24121's avatar
Doubstar_24121
Jan 10, 2012
BIG-IP Edge client with Ipad with FirePass
I have a problem when trying to connect to a FirePass remote SSL VPN site with IPad in combine with BIG-IP Edge client, after a couple of seconds the next error displays:
Authentication Failed. Please check your credentials or configuration.
I am 100% sure that the credentials are okay.
BIG-IP edge client v 1.0.2
FirePass v 7.0
Ipad 1 with software v 5.01
Edge client setting:
Web Logon = Off
User Certificates = Off
Thank you
--S
