jone14_166962's avatar
jone14_166962
Apr 06, 2018
Big-IP Edge Client seems not to work with Windows 10 1803
Hi everybody
Windows 10 Release 1803 will be delivered in the next few days to the public. We are running the latest build from the Windows Insider Program:
Unfortunately the Big-IP Edge client version 7160,2018,118,2335 (APM 13.1.0.5) is not working with this Windows build. The VPN connection cannot be established.
First error message in logterminal.txt [User]: Error CURDialer::InitializeConnectionThreadProc, Failed to set entry properties in C:\Users\AppData\Roaming\Microsoft\Network\Connections\Pbk\rasphone.pbk (error: 0x278)
Does anybody get the Big-IP Edge client worked with Windows 10 1803?
Thank you, John
