jmiller1284's avatar
jmiller1284
Feb 17, 2021
BIG-IP Edge Client Chain Disconnecting/Reconnecting
(Edit, after posting the logs I'm wondering if this might be a permissions issue)
Hi All,
I am about out of ideas here, and was hoping someone might know something. One of my end users is using the BIG-IP Edge Client to connect to the Library of Congress. The Edge Client connects successfully and is stable anywhere between 3 and 20 seconds. At that point it just disconnects, reconnects, disconnects, reconnects endlessly. Below are some of the things I have tried, as well as portions of the logs while this is going on.
-Spoke to the Library of Congress. They are not seeing any issues on their end. They provided a test VPN URL that they use for troubleshooting. Same issue happens there.
-Confirmed this isn't the client's local connection dipping
-Reinstalled the BIG IP client
-Uninstalled all Wan Mini Port adapters (BIG IP KB Article recommendation)
-Went over windows logs
BIG IP Logs from a test run attached.
