Foufou_15421
Aug 14, 2007BIG-IP Design Issues
I am pretty new in F5 world and I have 2 design related questions:
1. Is it possible to create 3 VLANs (with Web servers farms) on 3 different DMZs connected to a Firewall (ex: Cisco ASA) and have the LTM in a different DMZ connected to the same firewall through a 802.1Q VLAN tagged trunk?
2. I want to have 2 datacenters in Active-Active mode; can the Advanced Routing Module check the availability of my servers on one particular site and if they are down, send a routing advertisement to my router (ex: OSPF) to change the route to those particular servers to the second datacenter?
Thanks very much for your help.
Fouad
- Deb_Allen_18Historic F5 AccountHi Fouad -
1) Should be, if I understand the question correctly. If the network looks like this:LTM | DMZ0 | Firewall / | \ DMZ1 DMZ2 DMZ3 | | | servers servers servers
then you can use static routing on the LTM to route traffic bound for each DMZ subnet via the firewall interface.
2) Yes
You're very welcome.
/deb
