Better way to Cleaning UP string variable
Hi all
I must use the destination FQND of a TCP connection. I'm able to collect the TCP payload but I need to compare it with a data-class. But before doing that I need to clean the TCP payload variable
Here's what I have to clean: ......9net.tcp://sub.domain.com:12345/abcdefg... I need this finish with this : sub.domain.com
What is the most efficient way to achieve this : using regexp, string trim,
I want in fact the less CPU intensive way.
How about using scan?
If the variable string is set '9net.tcp://sub.domain.com:12345/abcdefg' or 'sometotherstuff9net.tcp://sub.domain.com:12345/abcdefg/lkjsdflkj/sdfl' etc then try using
scan $string {%*[^/]//%[^:]} fqdn
this results in a new variable $fqdn of 'sub.domain.com'
You can test it out by using the tclsh
% set string "lkasdflkjwe234239net.tcp://sub.domain.com:12345/abcdefg/sdlfkjasf" lkasdflkjwe234239net.tcp://sub.domain.com:12345/abcdefg/sdlfkjasf % puts $string lkasdflkjwe234239net.tcp://sub.domain.com:12345/abcdefg/sdlfkjasf % scan $string {%*[^/]//%[^:]} fqdn 1 % puts $fqdn sub.domain.comCheck out this link: https://devcentral.f5.com/articles/irules-101-18revisiting-the-tcl-scan-command
FYI I'm just starting to play with scan so YMMV.
Sheigh
- netadmindetail_
and I also the payload FQDN doesn't have the same length each time (different port, different path, different sub by customers) - Sheigh_65772
Cirrus
Sheigh
- netadmindetail_
Here's what I found.
Tells me if it's optimize or not.
set TCP_Payload [string range [TCP::payload] [expr [string first "://" [TCP::payload]] + 3] [expr [string last ":" [TCP::payload]] - 1]]
I must use an expr cause the string first and string last return only the first index.
Any other suggestion would be appreciated
- netadmindetail_
Both works
mine : set TCP_Payload [string range [TCP::payload] [expr [string first "://" [TCP::payload]] + 3] [expr [string last ":" [TCP::payload]] - 1]]
Sheigh : scan [TCP::payload] {%*[^/]//%[^:]} TCP_Payload
does the scan use regexp ? I heard that regexp is more cpu intensive.
I want to know which on is less CPU intensive ?
Thanks Sheigh for your output
- Sheigh_65772
Cirrus
From my reading scan is faster than regex: https://devcentral.f5.com/s/articles/so-yeah-regex-is-bad
- Sheigh_65772
Cirrus
Maybe I'm missing what your trying to do.
Here's another scan example:
% scan $string {%*[^:]://%[^:]} fqdn 1 % puts $fqdn sub.domain.comThis will exclude everything up until '://' which it will also throw out. From there it will match the remaining string until the next instance of ':' is found and put that into the fqdn variable.
- netadmindetail_
You didn't miss anything.
Both solution works. I just want to know which one is less cpu intensive.
- Sheigh_65772
Cirrus
Quick time comparison of the two:
% time { set fqdn [string range $string [expr [string first "://" $string] + 3] [expr [string last ":" $string] - 1]] } 10000 5.7755 microseconds per iteration % time { scan $string {%*[^:]://%[^:]} fqdn } 10000 1.2681 microseconds per iteration- netadmindetail_
Wow, thank you very much for this kind of output. Can you tell me how you've been able to grab this information ? Is this the time keyword ? how do you stop the timer ? - Sheigh_65772
Cirrus
So that was all from within the tclsh shell. From your f5 device just type tclsh and you'll drop in. The time command just takes what you want to run and runs it the number of times you specify: time { your commands } itterations
