Jeremy_Bridges_'s avatar
Jeremy_Bridges_
Jun 17, 2008
Best way to detect a certificate
Hello,
I have been trying to figure out the best way to detect and persist a client certificate using an iRule. It seems the best way is to use the CLIENTSSL_CLIENTCERT event to check for the certificate, then store it in the ssl persistence table with a timeout that is the same length as the SSL session timeout:
when CLIENTSSL_CLIENTCERT
if {[SSL::verify_result] == 0}
set cert [SSL::cert 0]
session add ssl [SSL::sessionid] $cert 3600
My real quandry comes when I try to check for the valid certificate in a general event used to handle the request. For, the CLIENTSSL_CLIENTCERT event only fires when a client certificate is sent to the server. If the client uses an abbrieviated handshake, no cert is sent, just the session ID.
Plus, it is unclear to me how exactly I am supposed to check for the existence of the cert in the persistence table. Any of the X509 functions (like X509::subject) will error if they try to operate on a non-existent certificate.
Here is what I have so far:
when HTTP_REQUEST
set clientCert [session lookup ssl [SSL::sessionid]]
if {$clientCert == ""}
SSL connection is bad
redirect to login page
HTTP::redirect "https://login.company.com"
else
SSL connection is good
if {[SSL::cert count] == 0}
abbrievated handshake
log "using abbrieviated handshake"
else
full handshake
log "using full handshake"
record cert into the HTTP header
HTTP::header insert ClientCertSubject [X509::subject $clientCert]
HTTP::header insert ClientCertIssuer [X509::issuer $clientCert]
HTTP::header insert ClientCertThumbPrint [b64encode [X509::hash $clientCert]]
HTTP::header insert ClientCertSN [b64encode [X509::serial_number $clientCert]]
So, I have three questions:
1. Can I retrieve the current SSL session timeout value? I don't really want to hard-code the value in the iRule.
2. Is there a better event to retrieve the certificate in besides HTTP_REQUEST?
3. Is there a better way to check for the existence of a certificate besides comparing to a zero-length string?
