NetSnoopy's avatar
NetSnoopy
Icon for Cirrus rankCirrus
Apr 13, 2017
Base64 ( b64encode) vs Base64Url Encode and Base64UrlDecode
Hello all,
The last days i had a lot of problems to build a iRule that contains strings with Base64UrlEncode. URLencode means replace "+" to "-" and "/" to "_" and cut trailing "=".
  1. URI::encode is not URL encode
  2. first do a b64encode
  3. replace string with "[string map [list + - \/ _ = "" ] $var]"
In a Irule shows like:
set var_b64_url "[string map [list + - \/ _ = "" ] [b64encode "$var"]"
But i do not have a solution to do this revers for Base64UrlDecode
my idea is
set var_b64 "[string map [list - + _ \/ ] $var_b64_url"]"
set var_decode "[b64decode $var_b64]"
But i don't have a solution for the trailing "=" ?
Cheers, NetSnoopy
  • Hi, it is an interesting your request, so I'll not ask what you are intending and just try a statement.
    set var_b64 "[string map [list - + _ \/ ] $var_b64_url]"
    if { [string length $var_b64] % 4 != 0 } {
        append var_b64 [string repeat = [expr {4 - [string length $var_b64] % 4}]]
    I hope it helps you.
