Bandwidth Control per IP
I am using vcmp and running v11.5.0 and going to use an iRule to limit the bandwidth per IP. I want to limit 1Mbps for each IP. When I test it by downloading a file from "192.168.10.24" and "192.168.10.100" simultaneously from the HTTP server in LAN, it seems that it does not work as expected because I find the total download speed is around 1Mbps. I have already configured to use Source Address in CMP hash. My iRule and BWC policy are below:
when CLIENT_ACCEPTED {
set ClientIP [IP::client_addr]
if {$ClientIP equals "192.168.10.24" or $ClientIP equals "192.168.10.100"} { BWC::policy attach BWC_user1_per_IP } }
root@(test)(cfg-sync Standalone)(/S1-green-P:ModuleNotLicensed:Active)(/Common)(tmos) list net bwc-policy BWC_user1_per_IP net bwc-policy BWC_user1_per_IP { max-rate 1mbps }
Is there anything wrong with my setting or the iRule? Thanks in advance.
- bonny_11145Historic F5 Account
Hi Chinay2K,
You've defined a static BWC. A static BWC is only concerned with the overall BW and does not actually set a per user (IP address) limit. Have a look at a dynamic BWC policy to allow per user max rate.
A definition of such policy looks like:
net bwc-policy bwc_per_user_dn { dynamic enabled max-rate 10mbps max-user-rate 1mbps }The policy above is limited to 10mbps in total and max 1mbps per user. HTH
