Background color and device name on big ip device
Background color and device name on big ip device on webgui after we login to device highlighting to which device we have logged in.
It should remain permanently when after upgrade.
Hi F5-Geek,
Configure Advisory Banner using the GUI
To access this feature in 11.6+ navigate to System > Preferences, change your view to advanced and scroll to the bottom of the screen and you will see an Advisory Section.
Credit goes to @Robert Teller 74374, see https://devcentral.f5.com/s/articles/easter-egg-big-ip-advisory-banner for more details.
- Andrew-F5
Employee
Hi F5-Geek,
For versions prior to 11.6 use the command below:
tmsh modify sys db ui.advisory.color {value “<red | orange | yellow | green>”}
tmsh modify sys db ui.advisory.text {value "TEXT GOES HERE"}
