Jay_Henriques_1's avatar
Jay_Henriques_1
Dec 07, 2011
b load returning parsing error
Line 20591 is this iRule but I can't find why it is the parsing is failing:
Velvet Rope Statistics
This irule monitor the current number of sessions within a velvet rope'd site. It performs an ajax call
to read the session table and compare that against the _manually_ set limit.
Not the most elegant solution, but effective. Apply this to a virtual server (not your main VS) and use
http://_vs-domain_/vrstatsDDE for statistics. (sub in your domain)
when RULE_INIT {
set static::site-identDDE "ddewcsp"
set subtableName "sessionLimit-${static::site-identDDE}"
set sessionCount [table keys -subtable $subtableName -count]
See if we're on the ajax request
if { [HTTP::uri] equals "/updatedSessionCountDDE" } {
HTTP::respond 200 content $sessionCount Cache-Control No-Cache Pragma No-Cache
} elseif { [HTTP::uri] contains "/vrstatsdde" } {
set responseContent "DDE Stats"
append responseContent ""
append responseContent "body { font-family: Sans-Serif; }"
append responseContent "p.headline { font-size:16pt; color: black; }"
append responseContent "p.subtitle { font-size:8pt; color: grey; }"
append responseContent "p.legend { font-size:8pt; color: white; }"
append responseContent "p { font-size:11pt; color: black; }"
append responseContent "var xmlHttp = null;"
append responseContent "function ajaxGetSessionCount() {"
append responseContent " var ss = document.getElementById('siteStatus');"
append responseContent " ss.innerHTML = 'Updating...';"
append responseContent " loadXmlHttp();"
append responseContent " sendRequest('/updatedSessionCountDDE');"
append responseContent "}"
append responseContent "function loadXmlHttp() {"
append responseContent " if (window.XMLHttpRequest) {"
append responseContent " xmlHttp = new XMLHttpRequest();"
append responseContent " } else if (window.ActiveXObject) {"
append responseContent " try {"
append responseContent " xmlHttp = new ActiveXObject('Microsoft.XMLHTTP');"
append responseContent " } catch(e) {}"
append responseContent " }"
append responseContent "function sendRequest(url) {"
append responseContent " if (xmlHttp) {"
append responseContent " xmlHttp.open('GET', url, true);"
append responseContent " xmlHttp.onreadystatechange = onCallback;"
append responseContent " xmlHttp.setRequestHeader('Content-type', 'application/x-www-form-urlencoded');"
append responseContent " xmlHttp.send(null);"
append responseContent "function onCallback() {"
append responseContent " if (xmlHttp.readyState == 4) {"
append responseContent " if (xmlHttp.status == 200) {"
append responseContent " var result = xmlHttp.responseText;"
append responseContent " updateBar(result);" append responseContent " } else {" append responseContent " alert('Error: ' + xmlHttp.status);"
append responseContent "function updateBar(ajaxSessionCount) {"
append responseContent " var gbb = document.getElementById('guestBarBackground');" append responseContent " var gcb = document.getElementById('guestCounterBar');" append responseContent " var csc = document.getElementById('currentSessionCount');" append responseContent " var ss = document.getElementById('siteStatus');"
append responseContent " if (ajaxSessionCount) {"
append responseContent " sessionCount = ajaxSessionCount;"
append responseContent " sessionCount = ${sessionCount};"
append responseContent " csc.innerHTML = 'Current count: ' + sessionCount + '';" append responseContent " var pct_full = sessionCount / ${static::climitDDE};"
append responseContent " var gcbWidth = (parseInt(gbb.style.width) * pct_full);" append responseContent " gcb.style.width = gcbWidth;"
append responseContent " if (gcbWidth == 0) {"
append responseContent " gcb.innerHTML = 'Empty';"
append responseContent " gcb.innerHTML = '' + sessionCount + '';"
append responseContent " if (pct_full >= 100) {"
append responseContent " ss.innerHTML = 'Site at Full Capacity: ' + Math.round((pct_full*100)*1000)/1000 + '%';"
append responseContent " ss.innerHTML = 'Site at Capacity: ' + Math.round((pct_full*100)*1000)/1000 + '%';"
append responseContent "Velvet Rule - Current Store Statistics"
append responseContent "Instance: ${static::site-identDDE}"
append responseContent "Current limit: ${static::climitDDE}"
append responseContent "Legend:"
append responseContent "Used Slots"
append responseContent "Available Slots"
append responseContent "subtable name: ${subtableName} "
HTTP::respond 200 content $responseContent Cache-Control No-Cache Pragma No-Cache }
  • hoolio's avatar
    hoolio
    Which LTM version are you seeing this on?
    Also you could make the iRule more efficient by setting the response content in RULE_INIT. You'd need to escape any commands or variables with backslashes (like \${static::site-identDDE}, \${static::climitDDE} and \${subtableName}) and then use subst to evaluate them in HTTP_REQUEST.
    Here's an example of the concept:
    http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/50/aft/30096/showtab/groupforums/Default.aspx30098
    Aaron
  • We are seeing this on v10.1.0. I will pass along your suggestion and earlier post to the irule author regarding moving the response to the Rule_Init to make the irule more efficient.
  • hoolio's avatar
    hoolio
    Can you try testing this to make sure it loads and functions properly?
    when RULE_INIT {
    set static::responseContent {
    DDE Stats
    var xmlHttp = null;
     loadXmlHttp();
     try {
     } catch(e) {}
     if (xmlHttp) {
     xmlHttp.send(null);
     updateBar(result);"
     sessionCount = \${sessionCount};
     var pct_full = sessionCount / \${static::climitDDE};
    Instance: \${static::site-identDDE}
    Current limit: \${static::climitDDE}
    Legend:
    Used Slots
    Available Slots
    subtable name: \${subtableName}
    HTTP::respond 200 content [subst $static::responseContent] Cache-Control No-Cache Pragma No-Cache
    Aaron
  • Thanks Aaron, that did the trick! Do you know why this was breaking config sync? Of course the SysEng/Dev team that wrote the irule had 4 others that were modeled after that one and had to be updated too.
  • Welll, that fixed the config sync issue but now the HTML code doesn't render. Looks like I'll have to work with the SE/Dev to get that worked out.
  • When I navigate to the site's /vrstatsdde, the variables do not get evaluated so the output is \${static::site-identDDE and \${subtableName}. Any ideas as to why the variables are not being evaluated?
  • can you try?
    [root@ve1023:Active] config  b virtual bar list
    virtual bar {
       destination 172.28.19.79:80
       ip protocol 6
       rules myrule
       profiles {
          http {}
          tcp {}
    [root@ve1023:Active] config  b rule myrule list
    rule myrule {
       when RULE_INIT {
    [root@ve1023:Active] config  curl -i http://172.28.19.79
    HTTP/1.0 200 OK
    Server: BigIP
    Connection: Keep-Alive
    Content-Length: 29
    rule myrule {
       when RULE_INIT {
            set static::responseContent \
    HTTP/1.0 200 OK
    Server: BigIP
    Content-Length: 7
    ddewcsp
  • hoolio's avatar
    hoolio
    You could use subst twice to get the variable values and not have to escape characters in the static content:
    when RULE_INIT {
    set static::responseContent [subst {
    unescaped text
    "hi"
    {text}
    < Connection: Keep-Alive
    < Content-Length: 45
    unescaped text
    "hi"
    {text}
    ddewcsp
    Aaron
