Jorge_Manya's avatar
Jorge_Manya
Feb 09, 2020
AVR crashed, it is not showing anything
Hello guys:
I hope ypu cpuld help me with the following question.
I renamed a virtual server with the procedure explained here https://devcentral.f5.com/s/question/0D51T00006i7k5A/how-do-i-to-rename-a-virtual-serverpool-name-on-a-f5-ltm- and such virtual server has a HTTP analytics profile and a TCP analytics profile. However the AVR module seems to be afected as there is no data in the statistics. I reset the database statistics by using https://support.f5.com/csp/article/K14956, but there is no data. The virtual servers are HTTPS and has the TCP and HTTP analytics profiles attached. How could I fix this?
Thanks.
  • Hi friend,
    Did you solve this issue?
    I faced same on past and Only restarting mySQL and run touch on avr file didin't work for me. So, I had to fresh install a new image and reboot to recreate all the things with success.
    Regards.
    • Jorge_Manya's avatar
      Jorge_Manya
      Hi friend:
      I solved that by issuing the "save sys config" command and rebooting the device.
      Regards.
