AST Configuration help
Running a deployment and I get to run the generate-config and eventually get a RESET ... any ideas?
sudo docker run --rm -it -w /app -v /home/user1/application-study-tool:/app --entrypoint /app/src/bin/init_entrypoint.sh python:3.12.6-slim-bookworm --generate-config
Unable to find image 'python:3.12.6-slim-bookworm' locally
3.12.6-slim-bookworm: Pulling from library/python
302e3ee49805: Retrying in 1 second
699edf835b1b: Retrying in 1 second
417a872b7725: Retrying in 1 second
9795987f6d21: Waiting
docker: error pulling image configuration: download failed after attempts=6: read tcp 1.1.1.1:50190->12.22.22.1:443: read: connection reset by peer
- BramsBytes
Cirrus
Might be just a temporary issue with the Docker Hub, I was able to download it just fine when I just tried it.
But the part where you list 1.1.1.1 as IPs always trigger me, but those might be for the purpose of obfuscation of course.
