TWSS_18275's avatar
TWSS_18275
Feb 11, 2008
Assigned Pool Info iRule
virtual vip_XXX.XXX.XXX.XXX_http {
destination XXX.XXX.XXX.XXX:http
ip protocol tcp
profile http tcp
persist cookie
pool vip_xxx.xxx.xxx.xxx_http
rule useragent_filter_http
It looks like the connection is assigned a pool and then the rule is run. Is it possible to see which pool is was assigned within the iRule? We'd like to do something if one pool is selected and something different if another pool is selected.
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    You can get the pool selected in LB_SELECTED event or later using the LB::server command (Click here
    LB::server pool
    /deb
