Stanislas_Piron
Jun 22, 2018ASN1 encoding decoding issue with ASN1::encode ASN1::decode commands
I am trying to work with ASN1 decoding.
As documented in wiki of ASN1::encode and ASN1::decode commands, I wrote this irule:
set tmp [ASN1::encode DER "aa" foo bar]
Convert to hexadecimal for log purpose.
binary scan $tmp H* tmp_hex
log local0. $tmp_hex
ASN1::decode $tmp "aa" data1 data2
log local0. "$data1 / $data2"
I also tried to add encoding type DER in ASN1::decode command :
ASN1::decode DER $tmp "aa" data1 data2
or
ASN1::decode $tmp DER "aa" data1 data2
But I always had this message:
Jun 22 17:20:07 F5ve info tmm1[12273]: Rule /Common/kerberos_decode : 0403666f6f0403626172
Jun 22 17:20:07 F5ve err tmm1[12273]: 01220001:3: TCL error: /Common/kerberos_decode - Invalid ASN1 Element (line 1) invoked from within "ASN1::decode $tmp "aa" data1 data2"
So Encoding commands works as expected:
- 04 means octet string
- 03 means 3 characters (length of "foo")
666f6f is the hexadecimal of foo
- 03 means 3 characters (length of "bar")
- 626172 is the hexadecimal of bar
but decoding commands fails and I don't understand why. it seems the command format is wrong, but I used the one described in wiki!
Is there someone who already use this command successfully?
