George_33482's avatar
George_33482
Feb 05, 2014
ASM iRule events not being triggered
Hello, I have an ASM version 11.4.0 HF5, i have an issue that the ASM iRule event actions are not being triggered. simple iRule: when ASM_REQUEST_BLOCKING { log local0. "test }.
Off course the "Trigger ASM iRule Events" has been selected in the security policy. when a violation occur, the irule is not triggered and no log in the /var/log/ltm or /var/log/asm
Any ideas!?!?!?!!? Help Please. Regards,
  • when ASM_REQUEST_BLOCKING { log local0. "test" }
    You didn't close the quote after test in the example you posted above.
  • Syntax looks correct. Obvious questions, but I'll ask anyway. The iRule is applied to the virtual server in question, and your ASM policy is in blocking mode?
  • yes the policy is in blocking and i am generating blocked violations, the iRule with ASM_Request_blocking event , binded into the VS is not being triggered.
    when i tried to add HTTP_REQUEST in the same irule and log something under this event, i can see logs being generated when this event fires.
    I am afraid I have to do something in the Local Traffic Policy......i don't know
    • Cory_50405's avatar
      Cory_50405
      Icon for Noctilucent rankNoctilucent
      Yeah, ASM underwent some changes in v11.4. I can't seem to dig up exactly what changed from an iRule events perspective though. I'll keep looking around.
    • Mike_Maher's avatar
      Mike_Maher
      What does the Local Traffic policy attached look like?
    • boneyard's avatar
      boneyard
      Icon for MVP rankMVP
      i pretty much did what you did and for me it works. did you attach a logging profile? can you create your own simple policy?
  • yes, it is working for me after trying another violations. actually, what i was trying to do is to test the information leakage (data guard), the page gets blocked and i can see the logs in the asm event logs. But, the iRule is not getting triggered. It seems that the data guard do not use the event action "ASM_REQUEST_BLOCKING".
    Thanks,
  • Hey, I´ve the same problem as you and I found the solution. You must activate the usage of iRule events into the ASM policy. The answer from the following thread has solved my problem. Now the iRule event ASM_REQUEST_BLOCKING will be executed. https://devcentral.f5.com/questions/where-in-f5-asm-do-i-enable-the-trigger-asm-irule-event-setting
