christopherlloy's avatar
christopherlloy
Sep 24, 2018
ASM iRest filter not working
Using the following iREST call, the filter does not seem to have any effect. No errors returned. ALL signatures returned even if 'performStaging' is not 'true'. This is f5 ASM v11.5.0
curl -k -u admin:admin -X GET /signatures?$filter=performStaging%20eq%20true
  • MD5 HASH got removed from URL above. Meant to send:
    curl -k -u admin:admin -X GET **HASH==/signatures?$filter=performStaging%20eq%20true
  • Try adding an escape for the "$" in the curl command.
    However the following is tested this on 11.5.4+:
    curl -sk -u admin:admin -X GET https://10.3.155.111/mgmt/tm/asm/policies/H7xqtWU5TfZJpeXDcC3xAA/signatures?\$filter=performStaging%20eq%20true\&\$select=name,id,performStaging | jq .
      "selfLink": "https://localhost/mgmt/tm/asm/policies/H7xqtWU5TfZJpeXDcC3xAA/signatures?$select=name%2Cid%2CperformStaging&$filter=performStaging%20eq%20true",
      "kind": "tm:asm:policies:signatures:signaturecollectionstate",
      "previousLink": "https://localhost/mgmt/tm/asm/policies/H7xqtWU5TfZJpeXDcC3xAA/signatures?$skip=0&$select=name%2Cid%2CperformStaging&$filter=performStaging%20eq%20true",
      "totalItems": 4513,
      "nextLink": "https://localhost/mgmt/tm/asm/policies/H7xqtWU5TfZJpeXDcC3xAA/signatures?$skip=0&$select=name%2Cid%2CperformStaging&$filter=performStaging%20eq%20true",
      "items": [
          "selfLink": "https://localhost/mgmt/tm/asm/policies/H7xqtWU5TfZJpeXDcC3xAA/signatures/1p7RmgJSYdJTivPK7b2b6A",
          "kind": "tm:asm:policies:signatures:signaturestate",
          "performStaging": true,
          "id": "1p7RmgJSYdJTivPK7b2b6A"
          "selfLink": "https://localhost/mgmt/tm/asm/policies/H7xqtWU5TfZJpeXDcC3xAA/signatures/7TlZ3m1ho4uFZKhO10RVlQ",
          "id": "7TlZ3m1ho4uFZKhO10RVlQ"
    Filtering for "false", then "true" and again without escaping the "$":
    curl -sk -u admin:admin -X GET https://10.3.155.111/mgmt/tm/asm/policies/H7xqtWU5TfZJpeXDcC3xAA/signatures?\$filter=performStaging%20eq%20false | jq .items[].performStaging | wc -l
    0
    curl -sk -u admin:admin -X GET https://10.3.155.111/mgmt/tm/asm/policies/H7xqtWU5TfZJpeXDcC3xAA/signatures?\$filter=performStaging%20eq%20true | jq .items[].performStaging | wc -l
    4513
    curl -sk -u admin:admin -X GET https://10.3.155.111/mgmt/tm/asm/policies/H7xqtWU5TfZJpeXDcC3xAA/signatures?$filter=performStaging%20eq%20false | jq .items[].performStaging | wc -l
    4513
    Reference questions which cover similar issues:
    <this linked content has been deleted>
    https://devcentral.f5.com/s/feed/0D51T00006n5aqRSAQ
