ASM GUI Preferences issue in 11.5.3
The first two options in the ASM GUI Preference section will be displayed twice and also modifying them is not possible (getting an error message):
Is this a bug in this version (there is currently no HF installed) or is there something other wrong with the device? I checked this on other devices running 11.5.2 and 11.5.4 and there everything is fine.
Ciao Stefan :)
- Hannes_Rapp
If you're out of ideas, try turning it off and on again 🙂
Try the command
first (restart GUI apache). This has no impact to trafficbigstart restart httpdIf the above doesnt help, try
during a maintenance windowbigstart restartStill broken? Open a support case with F5
- Stefan_Klotz
Cumulonimbus
Ok, restarting just the httpd-deamon doesn't help.
But besides that, where will these settings be stored? Is this within some conf-file or is this a db-value? Because then I would try to change it via command line.
Ciao Stefan :)
