WaterSoup's avatar
WaterSoup
Mar 15, 2022
ASM from blocking to transparent mode
Hello everyone,
I apologize if this has already been asked here on this forum, but from the search I did I only found the opposite question, which is normal.
Can anyone tell me what precautions or possible impacts there might be when changing the ASM from blocking to transparent?
And will it just stop blocking all violations or will it keep the blocks it has cached from the previous (blocking) configuration?
thank you all in advance for your time
  • Hi,
    If you set your policy from blocking to transparent, you going to stop blocking every attack that your application can receive, ASM doesn´t catch anything, the protection is applied in real-time in every request received by the Virtual Server.
    Do you have any special request ?
