SSHSSH_97332's avatar
SSHSSH_97332
Mar 02, 2012
ASM Class Questions
when creating an HTTP Class i can match based on host , URI or Header . URI is part of URL but what is host part ( is this IP address ) ? and what is meant by header ?
  • hoolio's avatar
    hoolio
    Hi sshssh,
    The manual has more info:
    BIG-IP Local Traffic Manager: Concepts
    Manual Chapter: Protocol Profiles
    http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/ltm-concepts-11-1-0/ltm_protocol_profiles.html1210980
    Note that you don't use the regexp command for doing case insensitive comparisons--you use regexp syntax like:
    (?i)www\.f5\.com
    to match www.f5.com without case sensitivity.
    Aaron
  • Thanks alot , it explains usage in good details but didnot mention meaning of host or headers ? can u give me example for each
