anand_4461's avatar
anand_4461
14 years ago
asm and ace forward and reverse traffic
Hi all,
In our datacentre setup , we have f5 asm & ace- cisco for loadbalancing
in which f5 is configured with self ip& below the selfip,the nodeip is there which is inturn the
virtual ip for Ace t2 context
the incoming traffic on f5 is like
Publicip:xx--> f5.selfip:80-->Ace virtualip:yy
for the ace request handling is of below
Ace.virtualip:yy-->Rserver:xx
but here the issue is that reverse http response flow is some what not analogous
rserver:xx-->f5.selfip:80 & back to the Public ip
myquery is that why the reply back from the rserver is not given back to ace virtual ip, but to the selfip of f5
  • myquery is that why the reply back from the rserver is not given back to ace virtual ip, but to the selfip of f5isn't it ace configuration matter? what is source ip when ace sends traffic to rserver? for f5, i guess it has snat setting, so f5 will use selfip when sending traffic to ace.
  • Yes , f5 has snat configured & selfip is the source ip that will hit on ace virtualip,but howcome the reverse traffic hits directly on f5 selfip from rserver...
  • Sounds like your return traffic is bypassing the ACE. Does the Rserver have the ACE as it Default Gateway?
