ab30_149107's avatar
ab30_149107
7 years ago
ASM - IP Address Whitelisting seems not working for x-for IP
Hi Team,
I am doing IP address whitelisting for some IP so that I should not learn asm suggestions from these IPs but its not working.
These IPs coming as x-for in learning suggestions.
Please suggest.
Thank You, Abhsiar.
  • IP address whitelisting only supports real client address.
    If you want to whitelist some client requests based on x-forwarded-for address, edit ltm policy used to assign the asm policy, add a rule above with http header condition and action ASM disable
