Append Forward Slash to base URL in browser - redirect using an irule
How could I set up a redirect as per https://webpage.com >> https://webpage.com/ For when a user does not put the forward slash in the browser .. and the server does not perform this function. I am across the fact the browser will / should always send a URI “/” even if not typed in .
Have tried the below does not work (e.g. with Mozilla) as browser is sending uri = “/”
when HTTP_REQUEST { if { [HTTP::uri] eq "" } { HTTP::respond 302 Location "; } }
Also the below will not work as it creates a redirect loop ..
elseif { [HTTP::uri] eq "/" } { HTTP::respond 302 Location “; }
Is this easily doable – acknowledging the fact this is / is likely to be cosmetic… subject to browser behaviour.
Hi Basil
The browser would always send an URI, no matter if you don't enter one or not. If you don't it will resort to "/".
The only way an empty uri would reach a server afaik is if somebody is manually compiling a request and sending it. And if it did, the web server would reply with a 400 Bad request.
Please check the example below:
echo -ne "GET HTTP/1.1\r\nHost:mywebsite.com\r\nUser-agent: Mozilla/5.0\r\n\r\n" | nc 172.30.175.33 5919 HTTP/1.1 400 Bad Request Content-Type: text/html; charset=us-ascii Server: Apache Date: Wed, 21 Dec 2016 05:12:39 GMT Connection: close Content-Length: 324 Bad Request Bad Request - Invalid URL HTTP Error 400. The request URL is invalid.The reason this is creating a redirect loop:
if { [HTTP::uri] eq "/" } { HTTP::respond 302 Location “https://webpage.com/"; }You're sending the user back to "/", which is set to send the user to "/"... and so forth. 🙂
Hope that answered your question?
/Patrik
Hi! I guess I should have been clearer in my answer too... 🙂
IF by slim chance some user would send a request with an empty URI your original rule would do it:
when HTTP_REQUEST { if { [HTTP::uri] eq "" } { HTTP::respond 302 Location "https://webpage.com/"; } }As for the forcing the browser to show "/" when the user accesses your site, this is purely on the client side.
- Chrome does not show it
- Edge does not show it (does not even show the protocol)
- Internet explorer shows it
But in all cases, what's sent to the server is another thing. Chrome and Edge still sends "/", they just don't show it. To change this behavior I suppose the browser settings would be a good start. 🙂
/Patrik
- stan_piron
Cumulonimbus
Hi Basil,
Can you post the request when requesting https://webpage.com?
the request must be:
GET / HTTP/1.1 Host: webpage.com User-agent: Mozilla/5.0 Connection: close
If the browser does not set the
, is there some string inserted between GET and HTTP?/How the F5 HTTP profile parse the request? does it raise an error? does it parse HTTP/1.1 as the HTTP::uri?
