sb_2323_80570
Jan 19, 2014APM Web top for authenticated user via edge client
Is it possible to present web top to user that is already authenticated using the edge client ? Im trying to use windows login credentials to auto login using the edge client and then user wants to fire up a RDP client from web top without entering credentials again. Any ideas if this is possible would be greatly appreciated
- Kevin_Davies_40
Nacreous
Edge client connects you like a VPN connection. Webtop is only available if the user uses a browser to connect to the APM.
- Maksim_57086
I would like to know either, if any possible way can make it. :)
