F51982_110427's avatar
F51982_110427
Feb 09, 2017
APM Values
Is there any documentation on the different values and or good examples of what happens when the data is passed through utilizing the values.
IE: expr return string
session.logon.last.username
session.logon.first.username
what would these values return -
IE:
session.logon.last.username  = expr { [mcget {session.ad.last.attr.sAMAccountName}]}
vs
session.logon.last.username  = return { [mcget {session.ad.last.attr.sAMAccountName}]}
vs
session.logon.last.username  = expr{ [string to lower [mcget {session.ad.last.attr.sAMAccountName}]]}
  • I certainly haven't seen much.
    The first, would return the sAMAccountName AD attribute (if you had an AD query object in the VPE that returned sAMAccountName).
    The second,I haven't tried using return, only ever expr, but i would assume the same as the above.
    The third, would be the same as the first, just all lowercase.
    HTH
  • Hi F51982,
    assuming that
    is set to
    DOMAIN\bob
    the following result can be expected.
    mcget {session.ad.last.attr.sAMAccountName} = DOMAIN\bob
    string tolower [mcget {session.ad.last.attr.sAMAccountName}] = domain\bob
    expr { [mcget {session.ad.last.attr.sAMAccountName}] } = DOMAIN\bob
    expr { [string tolower [mcget {session.ad.last.attr.sAMAccountName}]] } = domain\bob
    return [mcget {session.ad.last.attr.sAMAccountName}] = DOMAIN\bob
    return [string tolower [mcget {session.ad.last.attr.sAMAccountName}]] = domain\bob
    The difference of using a native
    command
    expr { [command] }
    or
    return [command]
    is non-existent if you just fetch an existing variable while passing it to a new variable.
    Only the advanced variable assign actions are making the difference between those commands.
    Example1:
    expr { ( [mcget {session.ad.last.attr.sAMAccountName}] contains "domain\bob" ) or ( [mcget {session.ad.last.attr.sAMAccountName}] contains "domain\tom" ) }
    Result: The above example will return the value
    1
    if bob or tom is loggin in and
    0
    for everyone else.
    Example2:
    if { ( [mcget {session.ad.last.attr.sAMAccountName}] contains "domain\bob" ) or ( [mcget {session.ad.last.attr.sAMAccountName}] contains "domain\tom" ) } then {
        return a ;
        return b ;
    a
    b
    for everyone else.
    Example3:
    set user [mcget {session.ad.last.attr.sAMAccountName}] ;
    if { $user starts_with "DOMAIN\\" } then {
        return "DOMAIN2\\[lindex [split $user "\\"] 1]" ;
        return $user ;
    sAMAccountName
    while rewriting
    DOMAIN\
    to
    DOMAIN2\
    Cheers, Kai
