APM stuck in initializing state after login
Hi.. after logging in to apm full webtop and start full vpn tunnel, it stuck in initializing state, then log me out! "/Common/all_access:Common:fbc7000b: Session deleted due to user inactivity" what could be the problem?
- youssef1
Cumulonimbus
Hello,
This behaviour occur only for you or for all users ?
regards,
- Yann_Desmarest_
Nacreous
it can be :
- DNS configured in the network access is unreachable
- proxy or proxy.pac is not accessible from network access
- no lease pool or no IP available for use in the lease pool
hope it helps
Yann
- zico_161532
thanks Yann
it can be :
hope it helps
Yann
- zico_161532
thanks Yann
- zico_161532
It was a testing lab before deployment!
- youssef1
Cumulonimbus
Hello Zico,
if it's testing lab, it will give us more flexibility to investigate.
So you have to type of deployement for Full VPN. You can use lease pool for your user (Specific IP) or just Snat (you will use a unique IP for all your user).
- Using Lease Pool
If you use lease pool you have to set in your Network access profil a lease pool and especially do not set snat pool just let defol settings (none). However you have to set Snat to automap in your VS that will host VPN service. Then you have have to set up the routing for lease pool that you want to use. to reach the lease pool for the return packages you have to define your floating IP as GW...
An fo cours open flow in your fw for let self, floating and lease pool reach proxy, proxy pac service, dns and all ressource that user have access.
- Without lease pool (snat automap set in network access profile):
the architecture is a little simpler because you do not need to manage the routing part for the leasepool.however, even though you set the snat pool to automap you still have to configure a lease pool even if it is not used (is mandatory). ...
Let me now if you need assistance.
Regards
