APM SAML IdP does not automatically redirect to SP and stays on webtop
I am currently trying to configure some cloud application with SAML 2.0 and my f5 APM as IdP.
Whenever I am authenticated by my IdP, the webtop with my SAML resources is displayed, which I do not want to see. Am I not supposed to be automatically redirected to my SAML resource ? Clicking on the SAML resource works well though, successful assertion is generated and my SSO to the distant application occurs.
As requested, my SAML resource is assigned as well as a full webtop just before the Allow box.
I am running 11.6 HF4.
Any help would be really appreciated :)
Thanks, Pascal/
- kunjan
Pascal, you may want to check this out
https://devcentral.f5.com/questions/saml-idp-initiated-connections
- Max_Q_factor
Cirrocumulus
You may also want to review Manual Chapter: Using APM as a SAML IdP no SSO portal
- InnO
I cannot remember how many times I read this manual before :). So I re-read it carefully and found the trick that made the difference : the last line specifying the SSO URI (/saml/idp/profile/redirectorpost/sso) which one must not forget if one does not use a metadata exported file. This is working fine now. I now have to refine my understanding of all that to make it work for multiple SP :) Thanks for your help, both.
