refra_151287's avatar
Nov 29, 2017
APM: OWA Two factor authentication Issue
Hello, - I've exchange 2010, we needed to add APM mainly to add 2FA on OWA, but don't want to pass any other service (outlook, Active Sync, ...) to 2FA baranch,
  • the OWA worked fine as expected, but for outlook it keeps sending authentication pop-up window, even when I enter the username and password it sends the popup window again.
  • I can see from the capture that the 401 HTTP response is coming from F5!
  • the issue disappears when I remove the access policy.
Normal Pass before adding 2FA
login page >> AD auth >> SSO mapping >> allow
after adding 2FA
landing URI (/Owa & /owa/)
>>brnach1>> logon page >> ADP auth >> variable assign >> RSA logon >> RSA auth >> variable assign >> SSO mapping >> allow
                        `>>branch2>> allow`
any help to bypass all service from Access policy, noting i tried all solution including disabled access policy inside template default irule!!
