Roman_178798's avatar
Roman_178798
Apr 11, 2016
APM is not forwarding authentication token to ADFS
Hello experts,
we configured ADFS on F5, in deployment guide, the name is Securing AD FS with the BIG-IP APM. Customer had another demmand, to authenticat with UPN only, not with SAMACCOUNTNAME. So I changed AD authentication to LDAP. User is able to authenticate via APM, but authentication token is not forwarded to ADFS. ADFS then see user as not authenticated and is not showing correct web page. I think, that problem is somewhere in policy editor, but not sure where. Could you please advice?
In LDAP search filter, I setup: UserPrincipalName=%{session.logon.last.username}, in SSO credentials mapping, we have: SSO Token Username - Username from Logon Page, SSO Token Password - Password from Logon Page.
Thank you for help
Roman
  • Josiah_39459's avatar
    Josiah_39459
    Historic F5 Account
    Since the LDAP auth applies only to the Access Policy, it has no bearing on the backend server. It sounds to me like your problem is likely in the SSO.
    You didn't say what type of SSO you are using, but if it is expecting the samaccountname and you are sending the UPN and they are different, it's obviously going to fail, right?
    • BigFoot's avatar
      BigFoot
      Yes, I am using NTLMv1, sorry forgot to add here. and setting is default.Just domain is different. According to application team, they cannot see any authentication attemp on ADFS
      Josiah_39459
      Historic F5 Account
      Well, a packet capture and websso logs (potentially debug) will tell you for sure. NTLM's just a http header. But it seems as a bare minimum you have to fix your SSO credential assign to be valid.
    • BigFoot's avatar
      BigFoot
      It takes some time, but I did packet capture, decrypt traffic, but it seems that user's credentials are not added to the NTLM header, so they are not passed to ADFS. Does anybody know please, how the correct setup should looks like for ADFS with authentication based on UPN and not SamAccountName?
  • Hi,
    If you configured SSO with Kerberos, requirements are:
    • SSO username must be the sAMAccountName user attribute
    • session.logon.last.domain must be configured with domain FQDN
    to authenticate with UPN with AD Auth, you can configure a AD query first with:
    • UserPrincipalName=%{session.logon.last.username}
    • attributes :
      • samaccountname
      • memberof
    Then Configure a variable assign to :
    • assign session.logon.last.username with AD attribute sAMAccountName.
    • assign session.logon.last.domain with variable session.ad.last.actualdomain
    After this box, you can authenticate user based on the new username variable, and Kerberos is configured with expected variables.
  • Hi,
    The VPE can be following:
    • Logon Page
    • query AD to retrieve following attributes (with filter UserPrincipalName=%{session.logon.last.username} )
      • sAMAccountName
      • memberOf (if you filter based on member group)
    • Variable Assign
      • session.logon.last.username = AD attribute name sAMAccountName
      • session.logon.last.ntdomain = Text COMPANY (static value as it is not store as AD Attribute)
      • session.logon.last.krbdomain = Session Variable session.ad.last.actualdomain
    • AD Auth
    • SSO Credential mapping
    Then in SSO, replace session.logon.last.domain with: - NTLM : session.logon.last.ntdomain - Kerberos : session.logon.last.krbdomain
    You can then choose one of both SSO method.
    For the Kerberos SSO, the user must be create with following parameters:
    • One PTR record on PTR on IP 1.2.3.4 --> adfs.company.local
    The delegation user mus be created with:
    • Samaccountname: f5deleg
    • UPN : [email protected]
    • SPN : host/F5deleg.company.local (defined with setspn command or editing attribute in attributes tab)
    • Delegation authorization: HTTP/adfs.company.local
    In Kerberos SSO:
    • User Realm Source - company.local
    • leave username source with default value (or session.ad.last.attr.sAMAccountName)
    • set domain source with session.logon.last.krbdomain (created in VPE above)
