Fab's avatar
Fab
Oct 01, 2021
APM Edge client popup header customization
Hello,
How can I customize the APM Edge client popup header color please (red arrow below) please?
I tried to change the "Header Backgroung Color" in "Quick Start/Basic" customization tab.
I looked at all colors in the "General" customization tab.
  • Fab,
    I have doubts that you can change that for the pop-up, as the Edge Client's a standalone app (yes, even though it's exported from your APM instance). I cannot say that with 100% certainty, but I would be surprised if it was possible.
    Thanks,
    Alan
