APM + LTM: Web socket issue
Dear Colleagues, I have been asked to configure load balancing on F5 between two web servers and provide secure access to it. I configured virtual server on F5 LTM and I configured access policy which allow user to login to application with using webtop. After implementation I get below error which affect.
Virtual server: WebSocket connection to ‘wss://URL’ failed: Error during WebSocket handshake: Unexpected response code: 504
Webtop + Virtual server: WebSocket connection to ‘wss://URL’ failed: Error during WebSocket handshake: Unexpected response code: 302
I use BIG IP in version 12.1.2 Should I configure come Web Socket profile on virtual servers, please could you advise?
- Jad_Tabbara__J1
Hello Wogo,
On your VS did you selected the default "Websocket" profile and tried with that one ?
- wogo1905_288591
When I try to connect with VS without APM I get below error WebSocket connection to ‘wss://URL’ failed: Error during WebSocket handshake: Unexpected response code: 504
When I try to connect with VS through APM I get below errors: Webtop + Virtual server: WebSocket connection to ‘wss://URL’ failed: Error during WebSocket handshake: Unexpected response code: 302 Uncaught ReferenceError: F5_Inflateindex is not defined.
On VS I applied profiles: TCP, WebSocket, HTTP, SSL (Client and Server), wancompresion, oneconnect
- Jad_Tabbara__J1
1) First of all, without F5 when passing directly, does it work ?
2) Then pass the VS_1 to "Performance Layer 4" without any profile except TCP ? Once you validate this, we can go further
- wogo1905_288591
Yes, when I connect to servers directly application works fine.
When I changed VS to Performance Layer 4 VS went down. It uses SSL profiles and they missed.
- Jad_Tabbara__J1
VS went down (red) ? how is it possible since you didn't make any change to your pool...
On which port you VS is listenning ? and on which port your backend are listenning.
Based on you this
On VS I applied profiles: TCP, WebSocket, HTTP, SSL (Client and Server), wancompresion, oneconnectI guess that both VS & backend listen on 443, can you confirm ?
