Sadhna_80746
May 01, 2012APIs to read zone resource record data
I was trying to use the following APIs to read zone and resource record data from F5 device and found following issues:
1. iControl::Management::ResourceRecord::get_rrs_detailed
RRList [] get_rrs_detailed(
in Management_ViewZone [] view_zones
The syntax says that the input should be array of Management_ViewZone.
But when I pass array of Management_ViewZone to it, it considers only the first Management_ViewZone in the array and ignores rest.
2. iControl::Management::Zone::get_zone
ZoneInfo [] get_zone(
I found the same problem as mentioned for the above API.
Am I missing something? Can someone please help on this?
- George_Watkins_Historic F5 AccountHi Sadhna,
Your assessment sounds correct The Management::ResourceRecord.get_rrs_detailed method takes an array of Management::ViewZone objects as an argument and returns an array of Managment::RRList objects. It is likely a syntactical issues. Here is a POC written in Java:package com.f5se.examples; import java.rmi.RemoteException; import javax.xml.rpc.ServiceException; public class GetDetailedResourceRecord { public static void main(String[] args) { iControl.BigIP bigip = new iControl.BigIP("test-ltm-01", "admin", "admin"); bigip.setIgnoreInvalidCert(true); iControl.services.ManagementViewZone[] view_zones = new iControl.services.ManagementViewZone[2]; view_zones[0] = new iControl.services.ManagementViewZone(); view_zones[0].setView_name("external"); view_zones[0].setZone_name("test.local."); view_zones[1] = new iControl.services.ManagementViewZone(); view_zones[1].setView_name("external"); view_zones[1].setZone_name("test2.local."); try { iControl.services.ManagementRRList[] rr_list = bigip.ManagementResourceRecord().get_rrs_detailed(view_zones); for (iControl.services.ManagementRRList rr : rr_list) { iControl.services.ManagementARecord[] a_records = rr.getA_list(); System.out.print("domain_name: "); System.out.print(a_records[0].getDomain_name()); System.out.print(", IP: "); System.out.println(a_records[0].getIp_address()); } } catch (RemoteException e) { // TODO Auto-generated catch block e.printStackTrace(); } catch (ServiceException e) { // TODO Auto-generated catch block e.printStackTrace(); } } }
Hope that helps,
George
