Joel_Newton's avatar
11 years ago
Anyone else having problems editing a question/discussion they created?
I created a discussion item earlier today and was trying to make a change. In the edit view, some of the formatting was corrupted (italics were replaced by _, and
blocks were added. Then when I tried to save, nothing happened.
Has anyone else experienced this? This happened in both Chrome and IE.
Thanks.
  • the edit option has worked better in the past.
    i dont get weird code blocks, but the text box is shifted odly to the right.
    saving works.
  • THi's avatar
    THi
    Same here; if you do editing after posting and have some formatting, especially special characters * , ^, bolding,... etc, most probably some of the formatting breaks after editing. Has been like that for quite a long time.
    In my view, it is not better than before.. so try to get your saying right in the first place, think twice what you post, and you will get better posts, too :o)
  • kunjan's avatar
    kunjan
    When comes to editing the post I use firefox. That seems to work. (edited)
