UncountedBrute_'s avatar
UncountedBrute_
Jun 18, 2018
Any tips, tricks or documents to help understand how to set up SSO for Portal Access Links?
My colleague and I have been struggling with this for a few weeks now. Does anyone know of any good documents or tutorials or even hints as to how to identify and set up SSO for a specific application being connected too via portal Access?
Thanks in advance.
  • I don't know documents, here is a simple way to know which SSO profile choose:
    • with firefox, open developper's tool
    • try to connect to web site from internal network
    • if authentication is requested within a web page, this is a form authentication
    • else check the status code (200, 302, 401, 500, ...)
    • if code is 401 ,this is Basic, NTLM, and/or Kerberos Authentication (multiple authentication can be enabled)
    Then if this is form authentication:
    • clear developper's tool, enable persistent logs
    • try to authenticate
    • the first request may be a POST (90% of Form authentication uses POST)
    • click on it, a panel on right side opens, go to parameters tab
    • you may see all POST parameters. copy these parameters.
    • close the browser, and try again from the beginning (with same credentials)
    • compare parameters with previous POST. if these parameters are the same, you can use Form-Based SSO, else, you must enable Form Client-initiated SSO
    If it is a 401 status code:
    • click on the 401 line, a panel on right side opens, Stay on headers tab
    • search for WWW-authenticate response header
    • if this header is BASIC : you can use BASIC SSO
    • if this header is NTLM : you can use NTLMv2 SSO (NTLMv1 is for backward compatibility)
    • if this header is Negotiate : you can use Kerberos SSO
    • If there are multiple headers, you can choose one in the list.
    After you identified the SSO method, you can read the admin guide on how to configure it.
