Any option/feature for SNAT-to-VIP other than using irule?
Is there any in-built features/options to achieve SNAT-To-VIP other than using irule? Appreciate your response. Thanks in Advance.
- Leonardo_Souza
Cirrocumulus
No idea what you mean by SNAT-to-VIP. Can you post the iRule, so we can understand what do you mean?
- Vijay_E
Cirrus
I don't understand your question. However, you can use iRule or SNAT pool with the VS configuration for enabling SNAT.
- Matthew_Hutchin
Hi Raaj,
No, there is no built in way to do what you are thinking. The only 2 ways are irule and using your VIP address in a SNAT pool. No, that does not cause an IP conflict.
Hope that helps.
Matt
- Raaj_313335
Thanks Matthew and Leonardo.
