Ambiguity re. Big-IP products
I'm doing a market research on selecting an ADC product among F5, Citrix, KEMP, etc.
I'm confused as to what the letter 'v' and 's' refer to in F5 Big-IP model names, e.g., 10250v vs 10050s. Is it 'virtual' vs 'software'. F5 datasheet is listing some hardware specs for 10050s (e.g. RAM and disk size etc) which is odd for a software-only product.
I understand F5 virtual editions can be deployed on different hypervisors. Is a model like 10250v delivered as a complete appliance, or it is just a Virtual Machines and we need to separately purchase the server hardware?
What is the approximate performance difference between a Big-IP hardware solution and the corresponding virtual edition? (i.e. how much do we lose by going for the virtual version)
- Kevin_Stewart
Employee
The v stands for vCMP - a hardware platform that runs an optimized hypervisor to provide for some number of BIG-IP "guests". The s stands for SSL - a hardware platform optimized for SSL throughput. Otherwise everything but the virtual edition is a hardware platform.
https://www.f5.com/pdf/products/big-ip-platforms-datasheet.pdf
The throughput of the virtual edition is dependent on 1) licensed throughput thresholds and 2) server hardware capacity.
https://www.f5.com/pdf/products/big-ip-virtual-editions-datasheet.pdf
- kianoosh_230995
Cool. Thank you for the clarification.
- Scott_McRoberts
I know this post if from a couple years ago but looking at some spec sheets at https://www.f5.com/pdf/products/big-ip-platforms-datasheet.pdf and notice the 4200v model although has a V (vCMP) says Virtualization (Maximum Number of vCMP Guests): N/A as does the 4000s. So are there some V models that can't do VcMP and you just have to check the spec sheets?
indeed, that is the wise thing to do, although the 4200v is the only odd one out i believe. with the iseries they stopped with the Vs again.
also keep in mind the 4200v and rest in that serie go end of sale soonish
https://support.f5.com/csp/article/K55590970
