Shirish_BasantR's avatar
Shirish_BasantR
Mar 11, 2020
alertd to trigger script after seeing specific syslog n times
i need to trigger an script after detecting a specific syslog. However, for dampening purposes i would like to see the same syslog 3 times before taking any actions, what is the best way to achive this?
Recommendation to use alertd : https://support.f5.com/csp/article/K14397
Recommendation to trigger a script: https://devcentral.f5.com/s/question/0D51T00006i7YqX/f5-to-run-shell-script-on-remote-host-in-certain-event
  • So you need to start with something like
    timelapseinlog.pl
    A utility script that can carry out a time-based filter on log files with various timestamp formats
    #!/usr/bin/perl -ws
    # This script parse logfiles for a specific period of time
    sub usage {
        printf "Usage: %s -s=<start time> [-e=<end time>] <logfile>\n";
        die $_[0] if $_[0];
        exit 0;
    use Date::Parse;
    usage "No start time submited" unless $s;
    my $startim=str2time($s) or die;
    my $endtim=str2time($e) if $e;
    $endtim=time() unless $e;
    usage "Logfile not submited" unless $ARGV[0];
    open my $in, "<" . $ARGV[0] or usage "Can't open '$ARGV[0]' for reading";
    $_=<$in>;
    exit unless $_; # empty file
    # Determining regular expression, depending on log format
    my $logre=qr{^(\S{3}\s+\d{1,2}\s+(\d{2}:){2}\d+)};
    $logre=qr{^[^\[]*\[(\d+/\S+/(\d+:){3}\d+\s\+\d+)\]} unless /$logre/;
    while (<$in>) {
        /$logre/ && do {
            my $ltim=str2time($1);
            print if $endtim >= $ltim && $ltim >= $startim;
    user_alert.conf
    this is the custom user alert that looks for logged events
    alert syslog_status_trigger_action "your critical message" {
      exec command="/shared/trigger_action.sh";
      exec command="/bin/logger -p local0.info 'action_triggered'"
    Then in your bash script trigger_action.sh:
    #!/bin/bash
    TRIGGER_LEVEL=3
    if [ ! -e /tmp/trigger_action_count ]; then
     # filter ltm1 and ltm into a single file so we don't miss events around log-rotation
      grep 'trigger_action' /var/log/ltm.1 > /tmp/trigger_action_count
      grep 'trigger_action' /var/log/ltm >> /tmp/trigger_action_count
      # set your time period below - I have chosen 10 minutes
      COUNT=$(/shared/timelapseinlog.pl -s=`/bin/date -d'now-10 minutes' +%H:%M` /tmp/trigger_action_count | wc -l)
      rm -f /tmp/trigger_action_count
      if [ -p $NP ] && [ "$COUNT" -gt "$TRIGGER_LEVEL" ]; then
          # do something here
      fi
    fi
    Note that there are some things that will not run in the alertd SELinux context (tcpdump, for example).
    You may need to run a script on startup that waits on a named pipe, and then the above trigger script signals using the named pipe.
  • You must be able to log in to the computer running your Orion server. Click Start > All Programs > SolarWinds Orion > Syslog Viewer. Click File > Settings liteblue.
