Aggregate pool monitor statistics using tmsh
Hi.
Does anyone know of a way to gather health reports of pool monitors? For example, I want to see how many times the health monitor dropped for member 10.10.10.1:80. I know you can pipe for this in /var/log/ltm such as 'cat /var/log/ltm | grep '10.10.10.1:80 monitor status down' | more' but is there a way to do this to get an aggregate report of all pool members across the system. So I can find out which pool members need critical attention, etc, etc.
Thanks, Ryan
- ryan_126547
Or even more important if this event occurs:
"No members available for pool"
to maybe send an snmp trap? I believe this would fit under trap ltmPoolMemberStatus ? The issue is I don't want to be notified every time, but under certain conditions, say if the instance occurs over 10 times a day. - nitass
Employee
The issue is I don't want to be notified every time, but under certain conditions, say if the instance occurs over 10 times a day.isn't it easier to configure on snmp server to notify administrator (e.g. email) when number of event exceeds threshold?
just my 2 cents. - ryan_126547
You mean email through some type of bash script? Do I have any other options utilizing the F5?
- nitass
Employee
You mean email through some type of bash script?i mean email from nms server. i am not much familiar about nms server but i think it could be configurable.
