Adding additional OID to LTM for Solarwinds monitoring
I am currently using Solarwinds to monitor the F5 LTMs.
Whenever I go to add the suggested OID's to poll for disk failures, I get the below message:"Unable to poll this OID on the test node. Try using a different OID or a different test node."
Here is an example of what i am trying to monitor:
1.3.6.1.4.1.3375.2.4.0.96
When i run the snmptranslate command on the LTM, I get the following message:
F5-BIGIP-COMMON-MIB::bigipRaidDiskFailure
When I run snmpwalk to the LTM for anything that starts with 1.3.6.1.4.1.3375.2.4, the text file is empty. Any help would be appreciated.
- Martin_Šebek_58
Check F5-BIGIP-SYSTEM-MIB rather than F5-BIGIP-COMMON-MIB. For example sysPhysicalDiskEntry gives some details about physical disk.
snmptranslate -m +F5-BIGIP-SYSTEM-MIB -IR -On sysPhysicalDiskEntry .1.3.6.1.4.1.3375.2.1.7.7.2.1Thanks for the update. We recently had an outage due to Disk Failure and our management wants to monitor for that specifically. I contacted F5 support and they suggested 1.3.6.1.4.1.3375.2.4.0.96, but i can't get it to work.
- Martin_Šebek_58
Unfortunately none of my systems has disks in raid so I see disk array status as undefined.
snmpwalk -m +F5-BIGIP-SYSTEM-MIB -v2c -c public localhost .1.3.6.1.4.1.3375.2.1.7.7.2 F5-BIGIP-SYSTEM-MIB::sysPhysicalDiskSerialNumber."WD-WMAYP0F5A3W5" = STRING: WDWMAYP0F5A3W5 F5-BIGIP-SYSTEM-MIB::sysPhysicalDiskSlotId."WD-WMAYP0F5A3W5" = INTEGER: 0 F5-BIGIP-SYSTEM-MIB::sysPhysicalDiskName."WD-WMAYP0F5A3W5" = STRING: HD1 F5-BIGIP-SYSTEM-MIB::sysPhysicalDiskIsArrayMember."WD-WMAYP0F5A3W5" = INTEGER: false(0) F5-BIGIP-SYSTEM-MIB::sysPhysicalDiskArrayStatus."WD-WMAYP0F5A3W5" = INTEGER: undefined(0)
